i kant seem to load the pick it wont let me but right beside the clutch lever there is a small hairline crack exactly right above the port in which u put the screw in very bottom right like i said right by the clutch lever and tranny fluid is leacking out of it pretty mild. it is a hairline crack i can barely see it till u see trany fluid coming out! i dont know what caused it but can i use something like some good jb weld to put over it and stop the leack?? any help appreciated thankyou
flip bike on side.....clean it real good. Then try jb weld. What's it gonna do if the jb weld fails...leak all over again? then your just in the same place..........dont' worry about it....just JB it.
