Alright i have a trued and welded crank. My original crank was trued and welded by a site sponsor which I used and re checked after 15 hours and it was way out of spec. I then bought this crank off Sleeper06 which came out of an 05. It was just checked and hasn't been ran since, so i guarantee is is within spec. $125 shpped
Cut transmission. This has the same mod done to it that HJR charges $200 for. I will also throw in the shafts forks drum and shift star if you need them. I need $135 shipped.
Ported cases including all hardware. $150 shipped
Billet wiseco clutch basket $110 shipped
Brand new in box heavy duty clutch pack. This clutch will hold 90 hp with the included drag springs.. I will also include the light/ medium spring combo. $75 shipped
money sent on basket and clutch kit.
Thanks bro!
Clutch sold
Basket sold
Transmission:
Every other dog is cut off 2-6 gear. What this does is effectively reduces the amount of missed shifts under power by 100%. IMO everyone should have this mod done to their tranny if they are running 55hp or more. It will cost you $200 plus shipping both ways if you send yours off...
Ok $275 shipped buys you
Cases, tranny complete with both racks of gears shafts forks drum modded star, hex fasteners brand new base gasket for ported, cub, serval engines, all coversbrand new clutch cover gasket flywheel +4 timing plate kicker gears everything in a complete bottom end minus the crank, clutch basket and clutch pack. Pressure plate is included.
Edited by SlowMoe
C'mon this bottom end is begging for a 4 mill crank.
Timing plate and shift star are both modded
