what mods need done to run alcohol
shaw211
it is .40 over with wiesco pro lites right now has duncan racing power head cpi pipes i was just wondering what the basic stuff for alcohol would be besides carbs
Thats it and learning how to tune a bike on alcohol is a whole lot different than gas. I am still learning how to tune alcohol. Burn marks are different.
hmm
need to gap at .18 on the plugs, make sure the ignition is REALLY good
need oil that mixes with alky castrol 927, klotz supertechniplate and redline alchohol oils?
need FRESH alky not that stuff thats in your buddies garage from 2 years ago that he gave you for free
if running ANY other carb besides lectrons you will have to drill dump tubes and buy needles and mains and much larger pilots. you will probably blow up a few motors from lean hangs and sucking the bowls dry or wrong jetting etc.
if you really want to go to alky the best "noob" alky carb is the lectron set up by PACKARD! MUCH easier to tune and much less likely ( but still will) to blow a motor.
its really best to have a experienced alky person help you out the first time
hmm
Cam Im glad you showed up and said something. Since I am new to alcohol myself and between you and Andy are teaching me about alcohol.
Drill your gas cap vent tube out bigger.
Pingle fuel valve
billet bowls
power jets
drill dump tubes
drill mains
bigger pilots
different needles
spark plugs gapped tighter
pickup coil gapped tighter
alcohol domes
oil that will mix with alcohol
purge when you're done.
