shaw211 Posted March 26, 2011 Report Posted March 26, 2011 hey new on here wanted to know what mods need to be done to run alcohol aside from jetting the carb Quote
TNTS355 Posted March 26, 2011 Report Posted March 26, 2011 hey new on here wanted to know what mods need to be done to run alcohol aside from jetting the carb You need carbs set up for alcohol, domes for alcohol (good but not required). Quote
shaw211 Posted March 26, 2011 Author Report Posted March 26, 2011 You need carbs set up for alcohol, domes for alcohol (good but not required). it is .40 over with wiesco pro lites right now has duncan racing power head cpi pipes i was just wondering what the basic stuff for alcohol would be besides carbs Quote
TNTS355 Posted March 26, 2011 Report Posted March 26, 2011 it is .40 over with wiesco pro lites right now has duncan racing power head cpi pipes i was just wondering what the basic stuff for alcohol would be besides carbs Thats it and learning how to tune a bike on alcohol is a whole lot different than gas. I am still learning how to tune alcohol. Burn marks are different. Quote
camatv Posted March 27, 2011 Report Posted March 27, 2011 hmm need to gap at .18 on the plugs, make sure the ignition is REALLY good need oil that mixes with alky castrol 927, klotz supertechniplate and redline alchohol oils? need FRESH alky not that stuff thats in your buddies garage from 2 years ago that he gave you for free if running ANY other carb besides lectrons you will have to drill dump tubes and buy needles and mains and much larger pilots. you will probably blow up a few motors from lean hangs and sucking the bowls dry or wrong jetting etc. if you really want to go to alky the best "noob" alky carb is the lectron set up by PACKARD! MUCH easier to tune and much less likely ( but still will) to blow a motor. its really best to have a experienced alky person help you out the first time Quote
TNTS355 Posted March 27, 2011 Report Posted March 27, 2011 hmm need to gap at .18 on the plugs, make sure the ignition is REALLY good need oil that mixes with alky castrol 927, klotz supertechniplate and redline alchohol oils? need FRESH alky not that stuff thats in your buddies garage from 2 years ago that he gave you for free if running ANY other carb besides lectrons you will have to drill dump tubes and buy needles and mains and much larger pilots. you will probably blow up a few motors from lean hangs and sucking the bowls dry or wrong jetting etc. if you really want to go to alky the best "noob" alky carb is the lectron set up by PACKARD! MUCH easier to tune and much less likely ( but still will) to blow a motor. its really best to have a experienced alky person help you out the first time Cam Im glad you showed up and said something. Since I am new to alcohol myself and between you and Andy are teaching me about alcohol. Quote
BigRed350x Posted March 28, 2011 Report Posted March 28, 2011 Drill your gas cap vent tube out bigger. Pingle fuel valve billet bowls power jets drill dump tubes drill mains bigger pilots different needles spark plugs gapped tighter pickup coil gapped tighter alcohol domes oil that will mix with alcohol purge when you're done. Quote
