We had to change the shift shaft seal on my fathers banshee, so I was powerwashing the case area. (all around the sprocket/seal)
As im powerwashing, i notice some white starting to appear.
I continue to finish, and for the first time noticed there is a white plastic plate with three screws there.
What exactly is this for? Can't believe I never noticed it before.
It's the cover for the hole in the case for the shift drum in the trans. It is also used as the neutral safety switch on the RZ350 stuff, but I am not for sure if the Banshee uses it or not...Evan
