  • 2 weeks later...
been workin on it.... the back came out good........ the front is a Maier replacement and its faded and not oxidized..... I'm having no luck with it......
I wet sanded with a 320 grit sanding sponge.... then with 1000 grit sandpaper........ then I used turtlewax rubbing compound..... then turtlewax polishing compound
That looks great man..i have had really good luck with McGuires PlastX. But it looks like you are doing fine with what you are doing. Props on saving yourself some money.
