Kev55 Posted March 5, 2011 Report Posted March 5, 2011 I just installed a twist throttle kit on my bike but it keeps acting weird. When i go riding it will sometimes get stuck and continue to rev even with my hand off the throttle. The thing is when it happens ill take the seat off and see the throttle valves are both sitting down at idle position. The needles are still properly attached to the valves so they close up the jets in idle position so i dont understand why its happening. I also sprayed the carbs and manifold w/ engine start to check for air leaks but i didn't find anything. Its fine when I just start the bike and it will idle fine but when i take it out and warm it up it will start to rev on its own and sometimes just die on idle. any suggestions? -Kev Quote
Kev55 Posted March 6, 2011 Author Report Posted March 6, 2011 Just an update but nothing is really burning in the left cylinder, it will burn sometimes and ill see smoke in high rev. but if i just put my hand behind the left pipe and gas it a lil my hand gets oil/gas spat on it and the left pipe will just be warm to the touch while the other will burn skin. i just changed my plugs and checked for spark but still having trouble. Quote
