SuperMex Posted March 1, 2011 Report Posted March 1, 2011 I have searched this and read sooo many different setups. Can someone please tell me if there is a easy way to change my stock plug wires and what wires/plug boots I can use part numbers and where to buy wiould be very helpful. Not sure why but my left side plug wire is too short and comes loose while i ride I think the previous owner cut it back and its just to short. Any help would be much appreciated. Quote
SheezFast02 Posted March 2, 2011 Report Posted March 2, 2011 (edited) I don't know where you would find replacement wires, but, you can find the boots at any bike shop. I just bought the NGK caps yesterday and they were only $13 for the pair. Just be sure to use the little rubber sleeves from the old boots to keep water and moisture out. Good luck. Oh yea, and to change the wires is super easy. Just remove the coil by unbolting the 2 mounting bolts, and unplugging the 2 spade terminal connectors. One wire is orange and the other is black. Once you have the coil in your hand, Very carefully bend the retainer tabs that are holding the wires into place. I suggest using your fingers very carefully and not a flathead screwdriver, as you'll break the tabs like I did. They're very brittle. Installation of the new wires is opposite of removal. Edited March 2, 2011 by SheezFast02 Quote
