485 cheetah, blocked pvs, 39pwk, 3000 ft elevation, needle on middle clip, 150 main, 50 pilot,. it won't idle, if i rev it up it will stay reved up really high with the slides closed? I tried diffent pilots jets 52 and 55
with the 55 it smokes really heavy and wont stay running, with the 52 pilot won't idle if I choke it, it will start and idle really high. its hard to start with any of pilots. how do I know if i have a bad cranck seal or air leak.
Need to do a leakdown test on it. 50 pilot seems big for it to still hang on idle.
Race gas or pump gas I'm guessing?
running on gas, with the 50 pilot when i rev it one time i couldn't shut her down she reved up real high the slides were down the throthle was not hung up
Your jetting sounds lean for 39mm carbs. I'd say you should be somewhere in the 160-165 range. My next question is, did you buy this from Trinity? How did the domes and head shell fit? There's been alot of problems lately with the 485's.
yes this engine came from trinity they put it together, how can i tell what size domes are on it with out pulling the head off. intake boots look good.
this engine has never ran right since we got it from trinity
Edited by 460yfz
If you pull the spark plugs out, you can view the top of the dome. It will say what cc they are.
Are you loosing coolant?
when the engine stayed reved up it started pucking antifreeze through the over flow but I thought that it was because the engine was warm,
the engine got sent back the first time becuse the cylinder had a pin hole loosing antifreeze, they said that they fixed it
Edited by 460yfz
We had a 421 cub cylinder that had a pin hole. It's been to millenium twice and hasn't been fixed correctly. Not saying Millenium doesn't know what they're doing, they definitely do. Just that it seems like this is a very difficult thing to fix.
:confused:<_<banghead Familiar story. :shrugani:
Here read this. http://bansheehq.com/forums/index.php?showtopic=131445 Read it all. your answers and the people you want to chat with about this are all in there. :unsure: Sorry to say...been there, done that. :angry:
Trinity :yank::flush::bolt:
if its leaking in a pin hole GET A NEW jugg its is impossible to fix. the casting had a problem i'd say its very hard to diagnose that problem till the motor is together and has coolant pressure on it.
if its puking antifreeze out the o-rings are blown or the head is not seated all the way or the o-rings have riped during install ( very very very hard to do on a cheeta)
its lean hanging possibly due to contamination in the chamber. get the coolant issuefixed first. then play with jetting. i have a coolant pressure tester that i use i do pressure AND vacume tests if the o-rings look fine.
also the o-rings should be brown in color NOT black.
thanks for the replys guys, I found the problem. is sucking air between the jug and the crank case you can run a .010 feeler gauge with ease, i bet I can run a thicker one in there.
jug is not seating down flat for some reason. bolts are tight. thats trinity at its best. I wish I knew how to post pics, I would take a picture of the gasket material that they put on the fron side of the case, about a 2 inch peace between the jug and case between the two front center bolts. some shaddy ass work
Don't think it ends there.......once you fix that you'll find the 3-4 other things that will destroy those expensive pistons in a heartbeat. Your domes are still junk. Everybody's 4 mill Trinity motor has junk domes.
485cc's of IED ....I own one too. banghead
