gstaten24 Posted February 26, 2011 Report Posted February 26, 2011 Hey everybody, so I think I might have finally figured out what is wrong with my shee, when I hit the thumb throttle the right side starts to pull the float up before the left does. Everything in the carb is equal on both carbs. Any ideas how I would fix this? Quote
sleeper06 Posted February 27, 2011 Report Posted February 27, 2011 cable free play adjustments on the carb tops,you can do it by eye or mark it with a scribe and measure if your anal Quote
gstaten24 Posted February 27, 2011 Author Report Posted February 27, 2011 Ok great thank you very much. That's what I originally thought but they're are both even as they are both all the way down. Could my cable be bad possibly? Quote
sleeper06 Posted February 27, 2011 Report Posted February 27, 2011 If the adjusters are all the way down free play was never adjusted,adjust them then sync the carbs with sync tool it could get rid of a gurgle due to slide heights,alot of times i use taller adjusters to get it how i like it Quote
gstaten24 Posted February 27, 2011 Author Report Posted February 27, 2011 Ok great thanks for the help! Quote
