A bit more info, I would use the same 39mm carbys, same dynatek ignition and the same out of frame drag pipes. Only change would be the pistons, barrels and head.
I got my answer from TDR he said
"A lot more torque and acceleration and about 15+ top end HP"
The only way the pipes will work if they are big bore pipes. 535 needs big bore pipes.
