SuperMex Posted February 12, 2011 Report Posted February 12, 2011 Looking to buy Serval soon I know transfer cases need to be ported to match, how much will i lose if I dont port them to match intake ports on the Serval? Andy at M&M says not really a big deal but i'm a lil skeptical. Quote
rubberneck Posted February 12, 2011 Report Posted February 12, 2011 I was told it was only worth about 2 hp on a cub when i built mine. Serval would be about same i imagine as its the same casting as the cub. I wouldnt sweat it Quote
06specialedition Posted February 12, 2011 Report Posted February 12, 2011 (edited) If Andy says it won't be a big deal, I would listen to him. These sponsors on here are the true banshee gods and they know there shit IMO. But I'm sure every little bit helps. Edited February 12, 2011 by 06specialedition Quote
SonOfSand Posted February 12, 2011 Report Posted February 12, 2011 Is your engine currently a 4 mil? If not, step up to a 4 mil (you will need a reinforced crank anyway) and while the cases are split, have the match porting done. Problem solved! Quote
SuperMex Posted February 12, 2011 Author Report Posted February 12, 2011 No its not but the 4mil Serval is the motor I'm going with just need to find someone local to do the porting I guess. Trinity is two blocks from me but I wouldn't let them wash my bike let alone port it. Quote
SonOfSand Posted February 12, 2011 Report Posted February 12, 2011 Well you can probably only port the cases when they are apart, so this will be the perfect time. 2-3 horse for 75 bucks, plus the peace of mind of no regrets. Quote
SonOfSand Posted February 12, 2011 Report Posted February 12, 2011 I think HJR is in So Cal, is that close to you? Quote
SuperMex Posted February 13, 2011 Author Report Posted February 13, 2011 I think HJR is in So Cal, is that close to you? HJR is about a 45 minute drive from me but I think I'm going to see if another builder I know can do some magic on them. Quote
camatv Posted February 13, 2011 Report Posted February 13, 2011 in my OPINION the cub, serv, cheeta all should have case porting done they also (in my opinion) MUST have the top case filled for better sealing on the base gasket. i also only use the cometic alluminum former base gasket for them ( the .18 tho one) its easy to see why IF you have it case ported the mis match from the cases is significant. Quote
eman1514 Posted February 13, 2011 Report Posted February 13, 2011 Looking to buy Serval soon I know transfer cases need to be ported to match, how much will i lose if I dont port them to match intake ports on the Serval? Andy at M&M says not really a big deal but i'm a lil skeptical. Quote
SonOfSand Posted February 13, 2011 Report Posted February 13, 2011 in my OPINION the cub, serv, cheeta all should have case porting done they also (in my opinion) MUST have the top case filled for better sealing on the base gasket. i also only use the cometic alluminum former base gasket for them ( the .18 tho one) its easy to see why IF you have it case ported the mis match from the cases is significant. Can you explain what you mean by "top case filled for better sealing on the base gasket"? Quote
sleeper06 Posted February 13, 2011 Report Posted February 13, 2011 I also use the .018 gasket,they epoxy the holes in the top case on front,back,some epoxy the transfer gullies as well as drill the holes out for better lubrication on crank bearings,In my opinion case porting is a must Quote
FASTOYS Posted February 14, 2011 Report Posted February 14, 2011 If your gonna have the cases apart i would recommend it then your bottom end is DONE and you wont have to tear it back apart to do it later. Worth about 2-3 hp. Quote
Snopczynski Posted February 14, 2011 Report Posted February 14, 2011 If your gonna have the cases apart i would recommend it then your bottom end is DONE and you wont have to tear it back apart to do it later. Worth about 2-3 hp. I personally would tear mine apart just to match port the cases even if it wasn't gonna be apart. Im anal though. Quote
dirtydownunder Posted February 14, 2011 Report Posted February 14, 2011 same, thats free hp. i think its different with stock cylinders than after market cylinders as retrieved hp goes, as the serval transfers are bigger than stock. so they may be a bigger increase than 2-3hp. id do it... SOS: when porting for a cub or a maxed stock cly, the base gasket transfer area gets a bit skinny, so you epoxy the outer sides of the transfer, so there is more surface area for the base gasket to seal between the case and the cylinder. Quote
