robert0762 Posted February 8, 2011 Report Posted February 8, 2011 I am going to bump up my compression some this year and have a few questions. i have a HJR mx hardcore port job 4 mill crank 28 pwks and pc pipes. I have heard that going to high on comp will hinder your topend. So I am wondering what is safe to run as far as comp numbers go. I am planning on running cam 2 110 octane mixed 50/50 with 93 pump gas and caster at 32:1. I dont know what my static numbers are now but i do knoe that the ex port is 28mm below deck. As far as the timimg goes i want to advance as much as poss also but dont want to much that it hurts topend performance. I am thinkin about gettin a dyna ign and getting someone to program me a custom curve. advance as much as i can for low and mid then pull it back on top. But if i dont do that will 6 deg be too much/ Quote
bbcmudtruck Posted February 9, 2011 Report Posted February 9, 2011 Generally stock cylinder motors afe run between 4-6 degrees. You'll just have to play with it and see where it likes it best. If your crank is welded, then I wouldn't worry about adding a little compression. I usually run around 180psi without issues. Be sure to run the correct amount of octane woth higher compression and more timing. Quote
252wheelieking Posted February 9, 2011 Report Posted February 9, 2011 (edited) Generally stock cylinder motors afe run between 4-6 degrees. You'll just have to play with it and see where it likes it best. If your crank is welded, then I wouldn't worry about adding a little compression. I usually run around 180psi without issues. Be sure to run the correct amount of octane woth higher compression and more timing. With a 180psi. do you run straight race fuel or race fuel/pump gas mixed 50/50? What timing do your engine reacts better to with your octane choice? Edited February 9, 2011 by 252wheelieking Quote
robert0762 Posted February 13, 2011 Author Report Posted February 13, 2011 Do I need to rejet when I raise my compression? Quote
06specialedition Posted February 13, 2011 Report Posted February 13, 2011 I run +5 timing and 19cc domes on my stock stroke with no problems. Quote
