So i am in the process putting a 4 mill in my banshee i have been buying parts here and there when the price is right and i got everything besides the 4mill crank... due to budget and other expenses occuring i don't have the cash flow right now to get one..... so i want to know if these 35mm PWK will be overkill or not with these mods until i get the crank it will have stock stroke, stock bore, dune port, coolheed with 21cc or 17cc domes, K&N pods, T5's, Vf2's reeds, intake spacers, and i think thats it i don't have the stock carbs no more so i can't put them back on so are these too much carb for to little motor or will i be ok
You will be fine,
NYCMarine was running HJR ported cylinders, 35's, DMC aliens on pump gas and the bike was a rocket.
Throttle response was insane from bottom to top, zero hesitation :headbang:
Joe
Alright thanks guys i know from experience on my big block in truck i had to big of a carb on there figuring the same concept here with the banshee and just had to check this out thanks for the info guys
