tipn22 Posted January 24, 2011 Report Posted January 24, 2011 F.A.S.T. sells them as well. Lots of people use those. They work awesome. 1 Quote
camatv Posted January 24, 2011 Report Posted January 24, 2011 they are cool to use. i have been using one for quite a while adn EVERY banshee needs the carbs synch by airflow instead of sight. i have done bikes with just pipes and nothing else they run killer afterwards. these synch should be available at local VW shops if you have one close to you. Quote
tipn22 Posted January 24, 2011 Author Report Posted January 24, 2011 they are cool to use. i have been using one for quite a while adn EVERY banshee needs the carbs synch by airflow instead of sight. i have done bikes with just pipes and nothing else they run killer afterwards. these synch should be available at local VW shops if you have one close to you. air flow is the right way if you like things to be at spec .going by eye maybe if you left your sync tool at home and you streched your new cable after riding it hard for a week Quote
MN SHEE Posted January 24, 2011 Report Posted January 24, 2011 I learned to use one of theas years ago on VW's before i got a shee work great even used it on some snomobiles this winter made a difference Quote
Hilarious Posted January 25, 2011 Report Posted January 25, 2011 Anyone figured out how to use these with power jets in the way? Quote
tipn22 Posted January 25, 2011 Author Report Posted January 25, 2011 Anyone figured out how to use these with power jets in the way? is this what yours looks like Quote
Hilarious Posted January 25, 2011 Report Posted January 25, 2011 is this what yours looks like kinda....... the power jets are in the bell end of the carb and wont let the sync tool penetrate (lol) the opening of the carb and make a seal to get an accurate reading. i havent really spent too much time tring to sync my carbs with this tool on my methanol bike, just tring to get both slides fully open all the way at the same time. other than that i agree with the sync tool's usefullness and for the most part works well. Quote
tipn22 Posted January 25, 2011 Author Report Posted January 25, 2011 (edited) kinda....... the power jets are in the bell end of the carb and wont let the sync tool penetrate (lol) the opening of the carb and make a seal to get an accurate reading. i havent really spent too much time tring to sync my carbs with this tool on my methanol bike, just tring to get both slides fully open all the way at the same time. other than that i agree with the sync tool's usefullness and for the most part works well. ok damn so what you will need to do is get a rubber gromment like i the pic so it will fit the sync tool and seel the very end of the carb not the inside hope this helps and might have to go online to find one big enough if your local hard wear store dose'nt have it Edited January 25, 2011 by tipn22 Quote
camatv Posted January 25, 2011 Report Posted January 25, 2011 go to the hardware store and buy 2 rubber plumbing connectors or maybe even one and cut it in half measure the throat of the carb. then drop the synch in it. your just setting idle and just off idle cable adjustments with it. NOT really anyting over that. there are also reducers you can use if it still dosnet seem to work well. i was able to synch lectrons with it i never really worried about getting an air tight seal they will read what ever is going throgh them if you seem to place the tool in the same spot in both carbs they seem to work well. Quote
KlotzBanshee Posted January 25, 2011 Report Posted January 25, 2011 OK, I got one of these from Jeffro around Christmas time and I haven't tried to use it yet. It's too fuggin cold to go out in the garage and mess with the banshee. Q? - Whats the deal with the holes in the sides of the middle boot? Do you line them up or what? Didn't come with any instructions. Quote
sprinklerman Posted January 25, 2011 Report Posted January 25, 2011 kinda....... the power jets are in the bell end of the carb and wont let the sync tool penetrate (lol) the opening of the carb and make a seal to get an accurate reading. i havent really spent too much time tring to sync my carbs with this tool on my methanol bike, just tring to get both slides fully open all the way at the same time. other than that i agree with the sync tool's usefullness and for the most part works well. Thats exactly why i use this one > http://www.summitracing.com/parts/EDL-4025 It seals against the face side of the carb bell. I know i've posted a few times lately about this particular part,but i really like it and i have no stocks in Edelbrock either! hehe Quote
