okay, today i just bought a 421 banshee 2005, but i want to swap it in my second banshee (1994) which a stock 2001 motor and classic goodies! and swap back my stock motor in my new 2005. do i need to swap all electrical wires too? is there someting i need to know?
Edited by 400sbc
The plug on the stator is different so just swap out the stators and you whould be good to go.
Sent from my Droid using Tapatalk
i mean swap entire motor, pipes, carbs etc. Is it like bolt on or i need to swap entire electrical, wire ,,,,?
What he means is you should be able to swap everything over but the wires coming from the stator will have a different plug on the end. Either swap everything or just switch the stator in both motors and you should be able to put the motor from the 2005 in the older bike using the older wireing haness. Just look at all the plugs on your harness.
