I have some 39 PWKs and my buddy has a set of 35s and they are both set up for alky with power jets
I have no idea how to get them to gas
I know to change the jets but what about the powerjet?
Also his is a 4mil stock cyl. with CPI inframes and +4 timing and we are at 5,300ft elev
What would be good jets for him
Thanks Cameron
You are going to need new carbs once the kehins dump tube is drilled for alky it is stuck a alky carb
Munki and lectron can go back to gas though
Thanks Cameron
Hate to tell ya, but the keihin carbs can't be swapped back to gas once they are set up for alky. The only way it can be done is if you have a seperate set of carb internal bodies you can unbolt and swap out, but to get the internal carb bodies you pretty much have to a second set of carbs set up for gas, which would make swapping the internal bodies a total waste of time.
The powerjets you could just close up if they haven't been drilled out. Some builders drill out the dump tube on the poerjets a little bigger, which doesn't let them ever totally seal up.
Long story short... you can't swap them back to gas.
how to convert m2ts to mkv
Why would we need to convert m2ts to mkv?
We know that m2ts is the video format that is widely used in high definition media. But many m2ts videos owners find it really difficult to when trying to play m2ts videos on PC and the laptop. On the other hand, mkv is a file frmat that holds numbers of video, audio, picture and subtitle reacks together, intended to serve as a universal format for storing common multimedia content. Therefore, if you want to share the m2ts files to media players or portable devices, to convert m2ts to mkv first can be a really good choice. To accomplish this process, you just need a m2ts to mkv converter. And things will be quite easy.
However, there are various m2ts to mkv converters nowdays on market. Here I just recommend one that I have been using during work for months. And its quality is much higher than average. This m2ts to mkv converter helps users to convert m2ts to mkv in a really fast way.
How to convert m2ts to mkv with the m2ts to mkv converter?
Firstly ,free download the m2ts to mkv converter and install.
Second, add files to m2ts to mkv converter. Click "files"-"load files from devices" or just drag your files to the m2ts to mkv converter. You are also allowed to add more than one files because batch conversion is supported with this m2ts to mkvconverter.
Third, select mkv as the output format through "Profil." You can see that besides "mkv", there are also lots of other video format. Yes, this m2ts to mkv conveter also support converting m2ts to other formats besides convert m2ts to mkv.
Four, if you wish, you can also edit your files in this m2ts to mkv covnerter. Before you convert m2ts to mkv, you can trim, crop, add effects and custimize the files in the m2ts to mkv video covnerter.
Five, now it comes to the last step, clicking "start" to convert m2ts to mkv. Within few minutes, the m2ts to mkv video covenrter will have your files converted from m2ts to mkv.
recommended articles:convert mts to mov,mts converter,m2ts converter,convert m2ts to mkv,convert avchd to avi,avchd converter,convert mts to mp4,mts to quicktime
