i was always told not to use starting fuild on a 2-stroke. because when it does fire it running on pure eitheir with no oil mixed in it . and if you do it to much or spray to much in you could burn up a piston ring or a bearing. second when useing strating fuild u spray it in the carb where the air filter connects, not in the spark plug hole.
