Quick question. I have the chance to pick up a head that has been milled .075" and .25 Degree angle re-domed VERY CHEAP. Machine work is freshly done. I've got an 04 Shee all STOCK. If I bolted this head on and added a +4 timing key would that combo work and what octane fuel would I need to run? I know this isn't the ideal setup considering I don't have pipes or anything but the deal I can get on this is almost to good to pass up. Trying to get the most power I can...cheap!
Pipes should always be the first mod for power on a Banshee. But after adding pipes some people want more low end and a cut head is an easy way to get that. If it is a smoking deal, I would buy it and then find a way to get some pipes.
  • 4 weeks later...
i picked up a stock head shaved .060 and all i run is 93 oct pump.Just run a thicker head gasket if your concerned but raising compression is a quick way to add power,cheap too.
Alright guys thanks for the quick replies. I guess I'll pass on the head fow now and just do a +4 Key only until I get money for some pipes. Thanks again.
DON"T put a +4 key in it, it will just lead to problems down the road:sheared keys, loose flywheels, and damaged keyways. Spend $50 and get a Chariot timing plate off of Ebay, make sure it is a billet Chariot piece and not a cheap cast one from RM Stator or Ricky Stator. If you did JUST the head you should be able to still run on 93 octane.
Edited by bansheesandrider
