How can you tell if a carb is setup for alcohol or gas? I just got a set of 35mm pwk and was just trying to figure out.
  • 2 weeks later...
usually they have a power jet in them and the main jet/ nozzle assembly with be very very big. usually the main jet looks HUGE much bigger than any normal gas jet due to being drilled out.
post a pic of the carb. most all the time they will need powerjets to supply enough fuel.
