could someone enlighten me on what the cushion are for when using a billet basket thanks?
actually a stock basket has them also, you just cant rebuild a stock basket. however, it just helps relieve stress on all of your components when using engine braking as well as common starting and stopping.
It does exactly like what it sounds like it does. It cushions the gear from the impact of the clutch basket when it starts rotating. It would be very hard on gears and your crank if the power transfer through the clutch was applied directly to the clutch basket gear.
