I just did the 450 conversion on the front suspension. I'm redoing my whole bike right now and was wondering if I will still be able to use my stock brake lines or will I need extended ones. I did the upper and lower a-arms, shocks, and spindles. I've only mocked them up on the frame just to do the mods before I send the frame out so I haven't been able to check the lines cause it's all torn down. I'm not sure what year they came off but I believe each arm is about 1inch longer than stock.
