Ruvalcaba Posted November 25, 2010 Report Posted November 25, 2010 Went to the track again but blew six gear on first run. I could only run 4 times. Best run was 4th one. Running 4mil full ported alky. Note that I was running 5th gear till the end on this run. I might have gotting a better result. 16/38 gearing 60ft. 1.489 330ft. 4.508 1/8mile et. 7.297 mph. 87.87 1/4mile et. 13.477 mph. 60.45 Quote
kubitza123 Posted December 1, 2010 Report Posted December 1, 2010 Not bad. I had a 4mill stock cy and weigh 210lbs with 5 speed trans and tyson single arm drag chassis ran 6.6 at 102mph with ease and and no wheelie bar. Mid - low 6's possible fairly easy . Quote
Ruvalcaba Posted December 1, 2010 Author Report Posted December 1, 2010 (edited) Not bad. I had a 4mill stock cy and weigh 210lbs with 5 speed trans and tyson single arm drag chassis ran 6.6 at 102mph with ease and and no wheelie bar. Mid - low 6's possible fairly easy . Thx for reply I'll try and get closer to ur time if I can. I've only had 7 runs on the 1/8 mile with this setup. I keep trying to run at least a 6.90 also what gearing u got on yours for five gears on the 1/8 mile? Edited December 1, 2010 by Ruvalcaba Quote
kubitza123 Posted December 8, 2010 Report Posted December 8, 2010 had 17/40 when i had that bike with stock ratio straight cuts 20.5-10x10 american racers and 205lb rider Quote
drap660 Posted December 8, 2010 Report Posted December 8, 2010 What length of swingarm are you guys using???? Quote
