gizmoman Posted November 20, 2010 Report Posted November 20, 2010 (edited) This winter i plan on tearing the shee down for a complete rebuild and i plan on moving up to a 4mil cub motor but im not really sure what i need. I want to get somewhere around 80-100hp on pump gas. Im new to this so any advice is appreciated i need some info on carb sizes,domes,exhaust,porting, and clutch and tranny mods to make sure it holds up. as far as riding style i do alot of open field full throttle riding and maybe a few trails but not alot so im looking for power to be focused on med-high range. Thanks in advance Edited November 20, 2010 by gizmoman Quote
dave5.0 Posted November 20, 2010 Report Posted November 20, 2010 From the sounds of it you might be a good canidate for a Serval. Maybe not a cub. I've got a ported cub that should be in the 100hp range. It's not much of a trail bike. Kinda creepy actually. I had a 4mill ported stock cylinder motor that was fun for trails and could still go fast in the open spaces. Little cheaper than a serval or cub too. Most builders can put you in that range pretty easy. There are a bunch of choices for carbs and pipes and all that. I would get ahold of a builder and tell them what you want to do and let them guide you. Then try and find deals on used stuff. That's the route I usually take. Good luck. Quote
too_fazt Posted November 20, 2010 Report Posted November 20, 2010 Youll need a phone and about 3 thousand bucks! calling a builder is the smartest move u can make! Quote
