you are controlling the fuel mixture if you have a hjr dune port this is a good start depending on pipes 155 mains and 48 pilots, you are good to go im running cel needles at about 1000ft
I know im controlling the air/fuel mxture, I found out its the air im controlling on the PJ's.....im at sea level, T5's, K&N pods, HJR dune/play port with the temperture ranging from 40-70 degrees. I think I need a 50 pilot jet. The 48 pilot jet only idles good & have good throttle response at .5 turns out. When I use my 55 pilot it idles good & has good throttle response at 1.5 turns out but it too rich.
