I got a 06 banshee with a cool head 20cc domes procercut pipes delta force reeds K&N pods i cant get it to idle and there is little to none exhaust comeing out of the left cylender and i cant really get a comp reading on the left side and i think its my piston rings what do yall think any advice will be grat thanks
Why can't you "get a compression reading out of the left side?"
Sync the carbs, then adjust the idle at the cable adjuster on the thumb trottle assembly.
