I wanted to see what some of your opinions were on this. I want to do a dune port on my stock stroke, stock bore motor. Would I be crazy not to true and weld the crank? I would love to go 4 mill but just don't wanna drop the coin right now. Should I just wait till I can do it all at once? Thanks.
YES you would be crazy not to true and weld your crank. I had my first crank seperate on my bike with nothing more than pipes on it. It cost me over $700 to repair the damage. You can true and weld the stock crank, you don't have to g to a 4 mil stroker crank to have it trued and welded. Also, if you port your motor for a stock stroke, you may not be able to use the cylinders on a 4 mil as the port timing may not work out with the longer stroke.
yah, if you plan on going 4mill in the near future, then it's best to wait untill you have enough to do it all, or plan on buying new un-ported cylinders to go 4mill........on the other hand, i think i saw a few sets of portd cyls for sale. you can always slap those on and then you'll have the cyls layin around for when you want to stroke :yank:
