Tapout1 Posted November 4, 2010 Report Posted November 4, 2010 Ok guys need help.... What steering Dampner would you guys recommend for the Shee??? I ordered an ALBA, but, it does not look sturdy. Any help will be appreciated. Quote
BenBB Posted November 4, 2010 Report Posted November 4, 2010 Ok guys need help.... What steering Dampner would you guys recommend for the Shee??? I ordered an ALBA, but, it does not look sturdy. Any help will be appreciated. I like my Denton, but I don't have anything to compare it to firsthand as it's the only brand I've tried. Mounts and works great though, I would recommend it. Quote
Tapout1 Posted November 4, 2010 Author Report Posted November 4, 2010 I like my Denton, but I don't have anything to compare it to firsthand as it's the only brand I've tried. Mounts and works great though, I would recommend it. Thanks for ur answer... Where does the Denton mount??????????????? Quote
Hank Posted November 4, 2010 Report Posted November 4, 2010 I recommend the ALBA steering dampner. Quote
BenBB Posted November 4, 2010 Report Posted November 4, 2010 Thanks for ur answer... Where does the Denton mount??????????????? It has a fairly thick aluminum bracket that mounts on the frame crossmember just above & rear of the upper bumper mounts, then the other side has an aluminum clamp that goes on the steering stem, so the stabilizer mounts more or less horizontal and front to rear. Quote
Tapout1 Posted November 4, 2010 Author Report Posted November 4, 2010 It has a fairly thick aluminum bracket that mounts on the frame crossmember just above & rear of the upper bumper mounts, then the other side has an aluminum clamp that goes on the steering stem, so the stabilizer mounts more or less horizontal and front to rear. Thanks Ben you have been very helpful.... Quote
