sleeper06 Posted October 27, 2010 Report Share Posted October 27, 2010 Those are them,installed boot to boot i get around 5.5 on the norm Quote Link to comment Share on other sites More sharing options...
Killswitch69 Posted October 28, 2010 Author Report Share Posted October 28, 2010 Those are them,installed boot to boot i get around 5.5 on the norm I checked out like 5 or 6 old OEM caps I had and not one could I get to read on my Fluke meter and I was testing from the pin on the cap to the plug clip. Why would these read OL, but if you put them on the coil the bike runs? I tested these caps by running 12vdc through them and the voltage was cut down to 3vdc. Is this typical of the stock caps? How is it possible that I can't get a an ohm reading but it still passes voltage? Quote Link to comment Share on other sites More sharing options...
AKheathen Posted October 28, 2010 Report Share Posted October 28, 2010 check your meter by touching the leads together....... Quote Link to comment Share on other sites More sharing options...
Killswitch69 Posted October 29, 2010 Author Report Share Posted October 29, 2010 check your meter by touching the leads together....... Zeros out and wire ends ohm 5.93k, so I know it is working properly. Quote Link to comment Share on other sites More sharing options...
CarvedArt Posted October 31, 2010 Report Share Posted October 31, 2010 ------- INFO The stock plug cap is a 5k resistor type. ------- QUESTIONS Have you verified that you have spark? (remove the plugs from the cylinders and kick the bike over while grounding the plugs out on the head) • Then if that's good did you remove the cap and try it with just the coil wire ends? Is the TORS connected? (disconnect the little black box w/ a 3-wire connector mounted on the upper-left front cross-member of the frame just under the front of the gas tank) Are the coil wires on the correct terminals? (ORANGE (+) & BLACK (-)) ------- TESTING --- PICKUP COIL First check the Pickup Coil gap it should be between .015 - .020 (about the thickness of a matchbook cover) --- PRI COIL Test the primary coil resistance between the 2 blade connectors on the coil you should get .28 ~ .38 Ohms If the primary tests bad, replace the coil --- SEC COIL Test the secondary coil resistance between each of the blade connectors and the corresponding plug wire; each one should be between 4.7 ~ 7.1 Ohms If the secondary tests bad, remove the spark plug boots and test without them. If the secondary tests good, replace the spark plug boots. If the secondary still tests bad, replace the coil. --- STATOR If both of these are good check the stator next: Disconnect the magneto connector (4-wire; GREEN, RED, WHITE/RED, WHITE/GREEN) and check the resistance between the GREEN and RED you should get between 13.7 ~ 20.5 Ohms If the stator tests bad, replace the stator assembly. Quote Link to comment Share on other sites More sharing options...
