dunerider4life Posted October 23, 2010 Report Share Posted October 23, 2010 ok so i just put a new clutch in my shee and when i went to take it out it wont disengage. its like its to tight and my cable is all the way out as far as i can go did i miss something? why would it act like this? i put it into gear and it wont move just idles. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted October 23, 2010 Report Share Posted October 23, 2010 ok so i just put a new clutch in my shee and when i went to take it out it wont disengage. its like its to tight and my cable is all the way out as far as i can go did i miss something? why would it act like this? i put it into gear and it wont move just idles. oh, i missed this bit in the shout.....after looking at the adjustment, remove the pressure plate and make sure it is seated all the way down on the hub. one of the arrows will line up with the arrow on the hub. before trying to put it back on, though, make sure there is not burrs on the splines. one rule of thumb- if it doesn't press the clutches together when you slide it on, turn it 1 bolt/spring hole and try again. Quote Link to comment Share on other sites More sharing options...
