was thinking about getting some reed spacers.. but im not sure what size i should get or if its rlly worth it for the mods i have
try the search button. This has been covered about 1 million times just like what pipes are the best.
Why do you want reed spacers? If your not trying to clear bigger carbs, I wouldn't even waste your time IMHO.
What mods do you have? What type of riing do you do?
Dyno port inframe exhaust
Boost bottle
Stock carbs, 310 main / stock pilot
Adjustable timing plate, set at +4
Case & cylinders ported
Boyesen power reeds
.040 over pistons
procom CDI box
Boost bottle
Boyesen power reeds
.040 over pistons
procom CDI box
Dynoport twin in frame pipes?
You never said what kind of riding you do.
yeah twin pipes.. a little bit of everything rlly not 2 much trail though
The spacers add mid and take away top, so if you dont ride trail, then you dont need to run them as a performance part.
