bad 350 shee Posted October 9, 2010 Report Posted October 9, 2010 well im not porting anything yet but iv read ALOT about it and am almost ready to try but i had a question about the durations how do i measure them and another thing what tools are you port urself guys useing?? Quote
AKheathen Posted October 9, 2010 Report Posted October 9, 2010 well im not porting anything yet but iv read ALOT about it and am almost ready to try but i had a question about the durations how do i measure them and another thing what tools are you port urself guys useing?? if you are even thinking about doing it to save money, don't. it will cost you upwards of $600 to get properly set up, 100 hours of reading and research to get started and a few sets of practice cylinders. look in repairs and mods under the stickie "useful links" for your primary literature. you use a degree wheel to get your timing durations. you need a 90-100 degree 1/8" tool to get into the transfers. 10krpm and/or cheapo 1/4" die grinder with a 1/8" collet will not do it. you can get away with a 1/8" strait for $40-$80 for the rest. shaping is a major part of porting, too. if you peruse the repairs section, there has been a tremendous amount of info posted this year alone. it even helps to study a used set of ported cylinders, too, even if they have exceeded usable bore. Quote
bad 350 shee Posted October 10, 2010 Author Report Posted October 10, 2010 well its something i wanna get into i ported a banshee cyl that was all fucked up and didnt do to bad i just dont wanna port a good set yet can you link me the info? Quote
MacRacer1 Posted October 23, 2010 Report Posted October 23, 2010 Ok so research out but done cylinders and practice and that will be probably the cheapest way to do it Quote
