2001 Banshee Partout
I'm starting a new ad, since my last ad became very difficult to see what is still for sale. PLEASE PM ME WITH QUESTIONS OR IF YOU ARE INTERESTED IN PARTS. I want to keep this ad clean so others can easily see what is available. All Parts are listed without Shipping fees.
Parts located in Danville, Pa, but I am willing to meet buyers in the Philadelphia area if buying something over $100
Billet Dip Stick $15
Modified Shift Shaft By FAST $25
2) Flowdesign Billet Waterpump Impeller $45 each
V Force 3 Reeds $100 Needs 1 new Pedal kit from Fast (cost on their site is $60 for replacement pedals)
Fast modded Shift star $15
Adjustable Timing Plate $25
Clutch Pancake Bearing $20
Fast UPP Chain Slider $15 Black
2) NOSS Billet Heads without Domes (Aluminum in color) $125 each
2001 Seat Factory blue and black cover (no tears) $35
2001 Stator OEM Not aftermarket $60
Clutch Pack (Springs, Plates, Fibers (Clutch material is the FAST kit) $35
Polished Dogbone $25
2000 Clutch Cover $30
Blue Plastics with cut front fenders $70
Frame Powdercoated (3stages, Chrome Base coat, Red Starlight Top Coat, Then Clear Coat, Frame has been lightened, and strengthed with aftermarket gusset kit Comes with Bill of Origin from dealer (NJ Bike) $300
2) 2001 OEM Stock Coils $35 each
Stock Gas Tank $15
2) OEM CDI unit 2001 $80 each
2) Complete Transmission gears with forks $110 each (both transmissions shifted great)
2) Stock Steering Stem $35 each
2) sets of 2006 YFZ 450 Shocks $180 per set
YFZ 450 Front Hubs $65
YFZ 450 Front Spindles $65
YFZ A Arms cut and with Spacers to bolt on to Banshee $200
2 additional sets of YFZ A Arms without spacers (need to be cut for Banshee use) $145 per set
Rear brake with block off, and disc $20
2 sets) Stock carbs Tors eliminator/cable (various jets) $100 per set
Gutted wiring harness with Kill Switch, dirt bike push button kill switch, grounds, and CDI relocation kit $100 (Does not allow for key, tors wiring, lights, or anything else that is not needed to run the bike)
Pile of Sunset sprockets (all are still in great shape, some have less than 2 hrs)$35
Front - 13, 14
Rear - 40, 41, 42, 44
Aftermarket Clutch Lever/stock cable got this through FAST $25
rear Skid Plate $25 (this has been used quite a bit)
Aluminum Nerf Bars with pegs (powder coated wrinkle Black with blue nets) $130
New AC Racing Aluminum front bumper Powder Coated Black $65
New AC Racing Aluminum rear Grab bar Powder Coated Black $55
Direct Drive Polished Lock Out Clutch cover/Lock out (clear lexan plate) $320
Brand New in box DynaTek CDI (Programable) for 97-06 Banshee. You can use this to increase timing and even setup a 2 step rev limiter (requires a Switched clutch lever which can be purchases from Pingel). $200
Alpine Star tech 7 boots size 9 $65
Thor Pants $25 size 32
Thor Shirt $20 Size Large
Thor Helmet some scratches $45
Additional Parts will be added this week.
Hey I'm interested in buying the dipstick and vforce reeds but its not letting me send you a pm for some reason can you pm me your info and ill get you paid and give you my shipping address. Thanks.
Updated list to show remaining parts for sale. All PMs have been responded to.
Stock Gas Tank $15
Front - 13, 14
2) Clutch Baskets in excellent shape with Boss and Pressure Plate $45 Each
Stator OEM Not aftermarket of off a 2001 Banshee $60
Clutch Pack (Springs, Plates, Fibers (Clutch material is the M&M Kit) $35
Stock Gas Tank $15
2) OEM CDI unit 2001 $65 each
2) Complete Transmission gears with forks $110 each (both transmissions shifted great)Both transmissions out of a 2001 Banshee
Gutted wiring harness with Kill Switch, dirt bike push button kill switch, grounds, and CDI relocation kit (metal bracket that fits behind the radiator) $100 (Does not allow for key, tors wiring, lights, or anything else that is not needed to run the bike)
Front - 13, 14
