someone82 Posted October 2, 2010 Report Posted October 2, 2010 I'm going to start running no rear plastics because I really dig the clean look, but how do I get the seat to sit more secure? Without the plastics it has has allot of side play. Quote
superswire Posted October 2, 2010 Report Posted October 2, 2010 My buddy had the same problem, make sure both front rubbers are good...look at your rear plastic where the seat sets on it...theres like a 1" by 2" patch on both sides that is decently thick, he just took some plastic squares (cut out of a junk air dam for a car we had laying there) and glued it to the seat to make up the difference...i guess you can use some sort of rubber which might be better too, if i did it, i'd use a piece of that hydraulic hose, its rubber, but tough as hell because its fibered to, pretty much just industrial radiator hose...then you have the option to glue it to your seat, or just zip tie it around your frame where the platstics sit...hopefully tou can do one of them and get yourself happy... Quote
xXBlessedWithDeathXx Posted October 2, 2010 Report Posted October 2, 2010 get a old piece of radiator hose / cut a slice threw it and zip tie it to the frame where the front of the seat slides in. that will stop the side to side motion of the seat. Quote
