Nutwood 472 Posted September 19, 2010 Report Posted September 19, 2010 Hey guys,just needing to know whats the other popular jet needle size is there for the 28pwk carbs,besides the n68a,which comes with them when you buy them,engine set up is 4mil,drag port,v-force3,6inch pods,stock cylinders,180 compression at 420 elevation,dyna tek cdi on curve three,high out put dyna coil,billit two piece intakes any info would be aperciated,thanks bhq Quote
SAVAGE420 Posted September 19, 2010 Report Posted September 19, 2010 I used to run the 30's and they came with JJH needles straight from CPW. I then got some N80F's and they were close, then finally got some N68A's and i found them to be Much better for my motor/mods and altitude. Going off a standard JJH needle ( N80F needle was close), and comparing with other needles. GJH: leaner taper, so leaner at ½-¾ throttle. LJH: richer taper, so richer at ½-¾ throttle. JJK: leaner diameter, so leaner towards ¼ throttle. JJF: richer diameter, so richer towards ¼ throttle. Bunch more. Quote
Nutwood 472 Posted September 19, 2010 Author Report Posted September 19, 2010 Thanks savage420,I'll let my friend know about the needle sizes and what to exspect with each one,thanks a mil man Quote
