09Shee09 Posted September 15, 2010 Report Posted September 15, 2010 Hi Guys can SomeBody help me please .. Were Does the Brown Rubber O rings go ?? Between the domes and the cool head shell or between the cylinder and the Domes Its Pro Design one Quote
Phelps Posted September 15, 2010 Report Posted September 15, 2010 brown goes between the domes and cylinders. Quote
09Shee09 Posted September 15, 2010 Author Report Posted September 15, 2010 brown goes between the domes and cylinders. Thnx No Any O ring Sits between the bottom of the domes ? Quote
Phelps Posted September 15, 2010 Report Posted September 15, 2010 Thnx No Any O ring Sits between the bottom of the domes ? i don't understand the question. the O rings will only go in one spot i believe. just sit the O rings in the tracks and you will figure out where each one goes. if there is a groove/channel there should be a O ring there. brown is high temp/high pressure O rings so they always go on the combustion side of the dome. Quote
