09Shee09
    09 banshee , because i am from middle east :) -Toomey T-5 Pipes -K&N Pods Cutted front fender :P
09Shee09's Achievements
  1. Thnx No Any O ring Sits between the bottom of the domes ?
  2. Hi Guys can SomeBody help me please .. Were Does the Brown Rubber O rings go ?? Between the domes and the cool head shell or between the cylinder and the Domes Its Pro Design one
  3. Thanx Guys
  4. This is My Friend's Shee , He is Using CFM lowering Kit , the Rear lowering block Can Be Adjusted for ride Height ..
  5. CFM Front and rear Lowering Kits http://www.cfmperformanceatv.com/bansheepropg.html
  6. Hi, I need to know What main jet size Should I Use My Mods : T-5 Pips K&n Pods and every Thing is stock I Drive in middle East .. Exactly in Qatar .. the elevation is 6.6ft I dont Know My premix ratio but I mix 20 L of 93 oct fuel With 1/2 L of maxima castor oil I havent Change Any thing in the carbs until now just the main jets and they are 260 now What is needle setting and were is the pilot jet located ? Sorry For asking too Much because I am Banshee Newbie
  7. Thnx , i found one
  8. Snop, can U send Me The wiring diagram for the DC Conversion and charging The Battery Pleeaaasee
  9. Thnx Much Snop
  10. is it ok to use the stock stator with these lights ? I cant find any reg/rec in trail tech web site any links :$ thanx alot snop for helping me
  11. I will install Ricky 200 watt Stator .. what Rectifier/Regulator Should I use ... ?? I dont need a battery ... and what kind of beam pattern should i buy for dune riding and long distance ? How can I mount the lights ? Sorry for asking too much
  12. Hi Guys .. Can Somebody Tell me What Exactly I need 2 do 2 Run These Lights Lights My shee has all Stock Electrics
  13. See My Signature
  14. Hi guys , Is there any good way to polish My plastics Because I feel That they are dull and not shiny Help Me please
  15. Use Meguiar's G12310 PlastX plastic Cleaner And polish they Will Do the work
