Hi Guys
can SomeBody help me please ..
Were Does the Brown Rubber O rings go ??
Between the domes and the cool head shell or between the cylinder and the Domes
Its Pro Design one
Thnx
No Any O ring Sits between the bottom of the domes ?
i don't understand the question.
the O rings will only go in one spot i believe. just sit the O rings in the tracks and you will figure out where each one goes. if there is a groove/channel there should be a O ring there. brown is high temp/high pressure O rings so they always go on the combustion side of the dome.
