GhostRider Posted September 10, 2010 Report Posted September 10, 2010 (edited) hi guys ... i need help knowing my harness 1: (2 black wires) 2: key 3: on/off & lights 4: (2 wires black/green) 5: coil 6: headlight 7: headlight 8: (3 black wires) 9: (2 yellow wires) 10: tors/ not sure 11: tors/ not sure i need to know 1/4/8/9/10/11 can anybody help? i removed the parking brake wire + throttle wire Edited September 10, 2010 by GhostRider Quote
brugal Posted September 10, 2010 Report Posted September 10, 2010 1. Is the throttle switch 4. Is the parking switch 8. Is the TORS box 9. Is the killer switch 10.Is the TORS carb top 11.Is the TORS carb top If Im not mistaken Quote
GhostRider Posted September 10, 2010 Author Report Posted September 10, 2010 Is the throttle switch: it connect with the front brake lever plug? or the throttle connecter? 9. Is the killer switch: which plug this one connect to? Quote
AKheathen Posted September 10, 2010 Report Posted September 10, 2010 if it's the '02 harness, there are going to be a couple things different than the diagram. 2 brake light wire plugs, at the bars, and toward the rear brake master cyl. if #1 is black and black/white, that is the killswitch that plugs in along side the light dimmer switch. they are actually 2 different plugs, not 1. if #2 really is the keyswitch, it will have black/red and black.(my 97 uses 2 wires out of the 4 wire plug.) i'm not sure on #9 without seeing the whole harness. what all wires have been removed/modified from the harness (colors) Quote
