gofast5 Posted September 9, 2010 Report Posted September 9, 2010 Well I got a motor in pieces and he took the trannsmission apart for some reason. I have a manual but its not doing me much justice on reasemmbling it other then the pictures. So I tryed eyeing it all up by picture and got it together but both sets of gears wouldnt sit competely down in the case it looked like I had to gears messed up. Well stupid me grabbed the trannsmission shaft and gears I didnt mess with and took it apart! Can someone show me a good diagram or pictures or something to get these things together??? Quote
bansheesandrider Posted September 9, 2010 Report Posted September 9, 2010 If you have the factory service manual, it will give a tooth count of every gear in the exploded tranny diagram. I don't know about a clymers manual as I don't use one. Or go to cheapcycleparts.com, go to the OEM parts section, input your info, go to the transmission picture and the bill of materials will have the tooth count of each gear. Quote
Koolguyson Posted September 13, 2010 Report Posted September 13, 2010 The blow up in the clymer is about as good as you're going to get. It doesn't get much better than a blown up schematic with tooth counts on the gears... Quote
AKheathen Posted September 13, 2010 Report Posted September 13, 2010 snagged this pic from the f/s section you should be able to get the gears lined out from that pic. Quote
gofast5 Posted September 17, 2010 Author Report Posted September 17, 2010 If you have the factory service manual, it will give a tooth count of every gear in the exploded tranny diagram. I don't know about a clymers manual as I don't use one. Or go to cheapcycleparts.com, go to the OEM parts section, input your info, go to the transmission picture and the bill of materials will have the tooth count of each gear. Thank you for the picture. I didn't see the tooth count ill have to look around again. Quote
