i just rebuilt my top end, eliminated the tors, and advanced my timing +4. and the left cylinder's compression is lower than the right, or at least it sounds and feels like it through the exhaust. i have switched the plugs and caps. any suggestions????
Did you do a compression test to 100% confirm the compression in both cylinders?
Listening and feeling wont tell you the compression.
hope its not less than a 10 psi defrence it wont run with less than 90 psi. good luck breakin it in.
where do i purchase a compression gauge?
Any local auto parts store near you will have one. Or borrow one from a friend .
Prices range from $20-$400 or so for a one.
