Phelps Posted August 29, 2010 Report Posted August 29, 2010 is there aluminum, or steel shims the go on the brake caliper mounting bracket? if so is fireball the only place to get them? maybe someone has this setup and can either point me in the right direction, or give me spec's on theirs so i can find some locally. thanks! Quote
Phelps Posted August 29, 2010 Author Report Posted August 29, 2010 i was thinking about it and maybe the mounting bracket on the carrier is what the shims come with, maybe? idk? i just know the caliper sets about 1/2-3/4" away from the bracket when sitting on the rotor. Quote
Nutwood 472 Posted August 29, 2010 Report Posted August 29, 2010 i was thinking about it and maybe the mounting bracket on the carrier is what the shims come with, maybe? idk? i just know the caliper sets about 1/2-3/4" away from the bracket when sitting on the rotor. pretty sure they come with the mounting bracket for the calipar,they sell the bracket kit with the shims or u can cut some aluminun stock and make your own,wouldn't be hard,I can measure mine 2morro and pm you,I run a lone star set up. Quote
Phelps Posted August 29, 2010 Author Report Posted August 29, 2010 pretty sure they come with the mounting bracket for the calipar,they sell the bracket kit with the shims or u can cut some aluminun stock and make your own,wouldn't be hard,I can measure mine 2morro and pm you,I run a lone star set up. if you don't mind that would be great, just in case i can't find a place to buy them separate. thanks! Quote
Nutwood 472 Posted August 29, 2010 Report Posted August 29, 2010 if you don't mind that would be great, just in case i can't find a place to buy them separate. thanks! no problem man,glad I can help. Quote
sleeper06 Posted August 29, 2010 Report Posted August 29, 2010 sit the caliper in there measure, go to ace hardware some peices and cut/grind to your spec if you go off someoneelse for a ballpark cool but double check Quote
