99bansheeworked Posted August 26, 2010 Report Share Posted August 26, 2010 is there a how to on remove the crankcase can you remove the bolt by the flywheel and the bold where the front sprocket is Quote Link to comment Share on other sites More sharing options...
Nutwood 472 Posted August 26, 2010 Report Share Posted August 26, 2010 is there a how to on remove the crankcase can you remove the bolt by the flywheel and the bold where the front sprocket is two engine mount bolts under crank case,4 engine mount bolts to remove engine Quote Link to comment Share on other sites More sharing options...
99bansheeworked Posted August 26, 2010 Author Report Share Posted August 26, 2010 o really you don't need to remove the bolt on the flywheelie where like the tranmission gear are. i think called the crankcase on one side and the other side where the sprocket thanks for fast response is i take a pic Quote Link to comment Share on other sites More sharing options...
99bansheeworked Posted August 26, 2010 Author Report Share Posted August 26, 2010 http://img801.imageshack.us/i/camf.jpg/ http://img441.imageshack.us/i/crank.jpg/ Quote Link to comment Share on other sites More sharing options...
toytech Posted August 26, 2010 Report Share Posted August 26, 2010 (edited) if you are trying to spit the cases? yes you have to remove those. do yourself a favor and get a flywheel puller from one of the site sponsors for under $20 so you dont ruin the flywheel! also buy a clymers manual they are very good to have on hand Edited August 26, 2010 by toytech Quote Link to comment Share on other sites More sharing options...
99bansheeworked Posted August 27, 2010 Author Report Share Posted August 27, 2010 i did buy one waiting for it Quote Link to comment Share on other sites More sharing options...
Nutwood 472 Posted August 27, 2010 Report Share Posted August 27, 2010 if you are trying to spit the cases? yes you have to remove those. do yourself a favor and get a flywheel puller from one of the site sponsors for under $20 so you dont ruin the flywheel! also buy a clymers manual they are very good to have on hand X2 on the book and puller and the bolt on the pressure plate will come out when you take out the six bolts and the hole clutch assembly will have to come off and kick starter and there will be a clip behind the clutch.it is a semi u shaped and has screws in it to hold tranny bearing"trans bearing retaining clip"has come off to split cases,seen alot of guys break them,trying to pry cases apart and dosen't take much to break the clip. Quote Link to comment Share on other sites More sharing options...
