SheezFast02 Posted August 7, 2010 Report Share Posted August 7, 2010 Was in the process of switching out the old carbs for PWK28's and noticed a crack in my left factory intake so I popped it off to find that my Shee is running Boyesen Rad Valves. So I am wondering, will this change how I should jet my new carbs? I got 158-160 mains and waiting for 52 Pilots. Mind telling me if this is right? -FMF Fattys w/ PC2 cans gutted -PWK 28mm with 52 pilot and 158 or 160 main -UNI 2stage foam filter -Airbox on.. NO LID -ModQuad Cool Head 21cc domes -Boyesen Rad Valve w/ carbon reeds -300' above sea level (approx) -36:1 Amsoil Interceptor with 91 Octane Also, should I have the clip in the middle groove on the needles, and how many turns out on the air screw? Thanks a bunch. Quote Link to comment Share on other sites More sharing options...
banshee67 Posted August 11, 2010 Report Share Posted August 11, 2010 your 150 ish mains seem extremely lox for your almost sea level elevation? i am running stock air box and filter with t 6 and their jetting and my mains are a 280. plus i am at around 4000 ft. my cousin went and bought the rad valve thinking that it would make his bike scream but my old man smoked his fmf fatties and rad valve alba racing banshee with his toomey t5 banshee. and it seemed that the rad valve made his bike loose some power. they work well for snowmobiles but just dont seem to work as well as the stock cages. boysen makes decent reed i am not bashing what so ever. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 11, 2010 Report Share Posted August 11, 2010 actually, he's right around the 3xx range. pwk/ kehin jet size numbers are different. and, you can't compare fatties and t5's on 2 differntly built bikes with 100variables and blame it on the reeds. ther's a reason t5's are a timeless favorite. oh, and the reeds are more midrance oriented. they should have minimal, to no effect on jetting. p.s. put the cans back together and pack them good. you will gain some power back. Quote Link to comment Share on other sites More sharing options...
banshee67 Posted August 11, 2010 Report Share Posted August 11, 2010 i will admit i like the toomeys and i have them but i still love the sound of those dinosaur fmfs. especially the fatties. but the too bikes were only piped. the abla packaga came with pipes, jetting and graphics. that was it. they were fairly even bikes Quote Link to comment Share on other sites More sharing options...
SheezFast02 Posted August 12, 2010 Author Report Share Posted August 12, 2010 Thanks for the help. Yea I'm going to be running Keihin PWK 28's rather than the stock Mikuni's, so the numbers are different.. For instance, I have 280 mains in the stock 26mm carbs. I've read a little about people packing the cans with pink panther insulation instead of the ripoff FMF kits. I think I'll try it. Thanks again. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 12, 2010 Report Share Posted August 12, 2010 i will admit i like the toomeys and i have them but i still love the sound of those dinosaur fmfs. especially the fatties. but the too bikes were only piped. the abla packaga came with pipes, jetting and graphics. that was it. they were fairly even bikes there is still many differnt variables, starting with one being jetted closer to what it needs, not just what the kit says, down to tire hook, rider weight nd skill, etc. you have to bolt the same pipes on the same bike, jetted right, with the same rider pitted against a controll, like another bike that keeps up pretty close, or time trials. then you can really compare the 2 pipes, and do the same for just changing the reeds. the point of the reeds is really to shape the power "feel" and response, more than just add power. that alone will make you ride a little differnt, too. the stock reeds do promote a peaky lightswitch power, and the boysen dual stage reeds will smooth that out and add a little power across the board, but there is several different ones to choose from. i don't think the cage comes loaded with the nice reeds unless you pay extra for it. as for packing material, i have used the pink insulation which you can buy in a "project pack" that is like 6'x 18", i believe, for sticking between studs, mabey longer. it did make it pretty damn quiet in comparison, but worked great. last time i was at the local mc shop, i found fly packing for $3.95/roll, which is enough to do a pair of toomy or procircuit silencers, but idk if it'll fill the fmf silencers completely. if you really want the loud sound back, you can always use copper pipe in the core, wich will work like a tuned stinger, but it's up to you to think about sound regulations and neibors, etc. and i wouldn't ride it without a helmet, since it will be loud enough to damage your hearing. Quote Link to comment Share on other sites More sharing options...
SheezFast02 Posted August 16, 2010 Author Report Share Posted August 16, 2010 I'll definitely be packing the silencers. I didn't gut them so they'd be loud. When I bought them from another HQ member, they needed to be re-packed and I haven't decided what to pack them with yet so I threw them on just to test run the new jetting. I live beside a cop station, so I don't want it too loud. Fucking cops around here have nothing better to do than to ticket people for having fun. I also wear a lid as well. Thanks again for your help. Quote Link to comment Share on other sites More sharing options...
VictorK Posted October 5, 2010 Report Share Posted October 5, 2010 there is still many differnt variables, starting with one being jetted closer to what it needs, not just what the kit says, down to tire hook, rider weight nd skill, etc. you have to bolt the same pipes on the same bike, jetted right, with the same rider pitted against a controll, like another bike that keeps up pretty close, or time trials. then you can really compare the 2 pipes, and do the same for just changing the reeds. the point of the reeds is really to shape the power "feel" and response, more than just add power. that alone will make you ride a little differnt, too. the stock reeds do promote a peaky lightswitch power, and the boysen dual stage reeds will smooth that out and add a little power across the board, but there is several different ones to choose from. i don't think the cage comes loaded with the nice reeds unless you pay extra for it. as for packing material, i have used the pink insulation which you can buy in a "project pack" that is like 6'x 18", i believe, for sticking between studs, mabey longer. it did make it pretty damn quiet in comparison, but worked great. last time i was at the local mc shop, i found fly packing for $3.95/roll, which is enough to do a pair of toomy or procircuit silencers, but idk if it'll fill the fmf silencers completely. if you really want the loud sound back, you can always use copper pipe in the core, wich will work like a tuned stinger, but it's up to you to think about sound regulations and neibors, etc. and i wouldn't ride it without a helmet, since it will be loud enough to damage your hearing. old post I know. What exactly is this fly packing and where can I find it locally? Quote Link to comment Share on other sites More sharing options...
AKheathen Posted October 5, 2010 Report Share Posted October 5, 2010 old post I know. What exactly is this fly packing and where can I find it locally? fly is just a name brand. just look around at local moto/power sport shops, or dealers for what's on the shelf... Quote Link to comment Share on other sites More sharing options...
banshee67 Posted October 6, 2010 Report Share Posted October 6, 2010 we use simple pink panther insulation. Quote Link to comment Share on other sites More sharing options...
VictorK Posted October 6, 2010 Report Share Posted October 6, 2010 we use simple pink panther insulation. in your opinion how is it compared to actual packing? Quote Link to comment Share on other sites More sharing options...
AKheathen Posted October 9, 2010 Report Share Posted October 9, 2010 it works fine, and no real difference at all in performance. i think it just sounds a little softer Quote Link to comment Share on other sites More sharing options...
banshee67 Posted October 11, 2010 Report Share Posted October 11, 2010 cheaper and and works fine. if you think about it, the silencers are glass packs like on a car. they use plain insulation and steel wool in them. so i would think that almost if not any type of insulation would work in it. just get a tight enough pack is all. Quote Link to comment Share on other sites More sharing options...
