wornout 89 Posted August 2, 2010 Report Posted August 2, 2010 Could I have a trans leak that is getting into my intake. My shee won,t run right on topend and no matter what size jets I use it still has oil on plugs. Giving it a rich reading. 89 w/ 28 mikuni flatslides toomey T5's 4 degree timming V force3 reeds Quote
SAVAGE420 Posted August 2, 2010 Report Posted August 2, 2010 Worst case is that your right crank seal is letting some leak in and its burning off slowly out the pipe. But look for leaks around the clutch cover gasket. Also check your coolant to see if its milky. Do a quick leak down too. Quote
wornout 89 Posted August 2, 2010 Author Report Posted August 2, 2010 Worst case is that your right crank seal is letting some leak in and its burning off slowly out the pipe. But look for leaks around the clutch cover gasket. Also check your coolant to see if its milky. Do a quick leak down too. Thanks now I have a place to start. Quote
SAVAGE420 Posted August 2, 2010 Report Posted August 2, 2010 Thanks now I have a place to start. Check back with your findings or if you need a hand. Quote
wornout 89 Posted August 12, 2010 Author Report Posted August 12, 2010 Did a leakdown test and found both crank seals were leaking. so I am going to pull the engine. Hope that's all I find. Quote
