I was wondering if anyone had ever mounted a tachometer on their shee?
Several people on here have mounted the TrailTech Vapor which has a tach built in. I tried one but had problems with the unit doing a full reset if you revved it up too high before the temp came. They replaced it once, after riding it I found the tach was to hard to read out on the trails so when I went back the second time, they gave me a Vector to try instead( I got to keep the Vapor) and also some other goodies. The Vector has no tach but for what I wanted( speedo, temp, and hourmeter) it is perfect and has worked flawlessly.
