MacRacer1 Posted July 30, 2010 Report Posted July 30, 2010 ok so on my 4 mil the piston froze i took it apart put new pistons in lubricated it if i put it back together do you think it will start also what are some tips on making sure the piston doesnt freeze? Quote
Larry's Shee Posted July 30, 2010 Report Posted July 30, 2010 ok so on my 4 mil the piston froze i took it apart put new pistons in lubricated it if i put it back together do you think it will start also what are some tips on making sure the piston doesnt freeze? To keep it from "freezing" keep it out of the cold !! To keep it from seizeing you need proper piston to cylinder clearance and don't run it lean. Quote
MacRacer1 Posted July 31, 2010 Author Report Posted July 31, 2010 ok well it sits in a garage garage thats heated to 55 should i start it weekly or something then Quote
bansheesandrider Posted August 1, 2010 Report Posted August 1, 2010 While a piston may be frozen, it probably won't be stuck to the bore. It has probably siezed becuase you had incorrect clearances, it was not broke in properly, or you ran it lean and/or overheated it. Quote
