AKheathen Posted July 25, 2010 Report Posted July 25, 2010 so, yah, 2 things- i'm wondering if there is someone who can work with me to cast, or cnc some new design intakes. 2nd- i need some measurements fom guys running billet intakes already. i plan on using just genaric bolt-on carb boots, so i need the bolt spacing, and flange measurements. more importantly- i need the distance from the reed to the boot flange, and if you needed to use reed spacers to clear the carbs, that thickness and which carbs, as well. i don't want to design an intake that needs spacers to clear the carbs. thanx a bunch. Quote
