like topic say's what do you guys think is better?
for real? well if you want a piston that doesnt require "warm up time" and are not needing the pistons to withstand high hp then stay with ART pistons.
if you need a piston that can be beat on, no worry's of premature failure and a stronger all around piston then go wiseco.
X2,I have seen to many broken skirts on stock pistons to not use a good piston(Wiseco).
