i got a couple ?'s i'm taking apart my clutch to do the shift shaft mod and star. first timer here. reading the manual it say's to stack clutch plates in order which i did until my daughter accidentally knocked them all over my work bench. so is it that big of a deal? another ? is i removed the screw from the star but it will not come off. is there some tricks for this?
the stock, oem steels are supposed to be installed staggard. i believe its like.......30deg each one?
the star should slide off your shiftdrum with the screw removed. may have to coax it a little bit.
cool thanks for the help guy's also is there a way to tell if i have HD clutch springs?
OEM springs should have a yellow or green paint to them. The others are plain steel.
